Vibratii suspensie + directie pe viraj
I received a private message knowing that I'm not answering. The following response:
In Brazil all the "Duster" are experiencing the problem of vibration. Renault's explanation is that this is a feature of the car to be high and wide tires. This does not convince anyone, because there are several other models of SUVs of different manufacturers, with superior features in height and size of tire that does not have this problem.
Regarding the second problem, the information circulating on the Internet is that it is a balancing weight to the car and prevent vibration. What you can not understand is why the piece is rusted. I can post a photo, you can guide me how to do?
I also ask, who can, guide me how to reply to messages, because the problem may be to translate the page.
thank you
The photo has to be less than 700kb in order to be posted!
OK, you could guide me the steps to post the picture?
  • Răspunsuri 188
Nu inteleg de ce puneti 2.2? Pe stick-ul lipit de caroserie scrie 2.0 pe toate (pentru utilizare normala - asfalt). Eu asa am umflat rotile si nu am nici o bataie/vibratie in roti. 0.2 e o diferenta
Cam ce-ar putea afecta (negativ sau pozitiv) o presiune in roti "setata" la valoarea recomandata de producator? 2.0 este presiunea la care toate testele facute cu aceasta masina au iesit exact asa cu
Ceea ce ati observat amandoi (un zgomot asemanator cu roata frecand un plastic) se numeste ASR si este foarte normal in momentul in care una (sau mai multe) din roti are o turatie diferita de celelalt
thank you
When you write a post you have under the writing box another area where is write "incarca fisier atasat". you have there a button with "Choose file". After you choose the file you press on "Adauga fisierul" and you will post the picture
Salut!
Nu stiu daca aceasta intrebare merge ca si raspuns aici sau ca si un post nou, dar:
Problema aceasta cu vibratii la viraj, batai in volan (care provin sau nu de la caseta de directie (facuta sau nu la noi)), afecteaza toate modelele noi de Duster?
Adica, daca as cumpara un Duster nou ;) , e 100% ca voi avea acea problema? Sau sunt afectate doar anumite modele, dintr-un anumit lot?
Alta nedumerire a mea este daca nu cumva toate masinile sunt afectate dar pe unii proprietari nu ii deranjeaza considerand acest zgomot ca si normal.
Daca puteti sa ma lamuriti. As dori sa-mi iau un Duster, dar n-as vrea o masina noua cu probleme la directie din fabrica.
Multumesc,
Alex.
Salut!
Multumesc,
Alex.
Eu pot sa-ti spun ca nu am aceasta problema.
2x4, 110 CP, 1,5 DCI, 2011, 43.000 Km, masina face la fel si mai face ceva in plus... la acceleratii puternice chiar cu rotile drepte se aude ceva care parca seamana cu frecatul rotii de caroserie, insa nu ma stresez prea tare o repar daca o sa cada de tot.
insa semnez petitia daca mai este valabila ideea.
Va salut cu respect
Confirm si eu aceste zgomote. Eu le-am observat pe drumuri denivelate si recunosc, ca m-am chiar gandit, la ideea ca din cauza denivelarilor, roata freaca de ceva anume...idee de la care nu m-am abatut inca...:) Eu le aud undeva in spate, centru spate, nu neaparat in fata, deci cred, ca nu ar avea legatura cu caseta.Referitor la vibratiile datorate casetei, acestea s-au diminuat foarte mult, odata ce am schimbat anvelopele de vara cu cele de iarna. Cele noi sunt foarte moi, cateodata ma gandesc la franari bruste sa nu raman fara ele, sa le gasesc intinse pe asfalt..:). Probabil, din cauza asta nu mai simt vibratiile. De schimbat nu o sa schimb nici o caseta, atata timp cat merge.
In rest, e super prafosu....
Ceea ce ati observat amandoi (un zgomot asemanator cu roata frecand un plastic) se numeste ASR si este foarte normal in momentul in care una (sau mai multe) din roti are o turatie diferita de celelalte. Calculatorul incearca sa simuleze blocarea diferentialului prin franarea rotii care merge mai repede astfel incat sa transmita cuplul rotilor care au aderenta mai buna.
Se poate intampla: la demaraje puternice; pe carosabil umed; noroi; zapada; in curbe stramte luate "putin" prea tare :roll: etc. Daca aderenta nu se re-egaleaza pe roti, dupa aproximativ 1 secunda se simte cum calculatorul da sa taie gazul pentru a ajuta rotile sa-si reia aderenta si palpaie martorul ASR in bord.
Practic, zgomotul este produs de frana pusa de computer pe una sau mai multe roti, frana in impulsuri foarte scurte si dese.
Din experienta proprie confirm acest ASR ca fiind una din cele mai bune/utile dotari gasite de mine pe Duster 4x4.
Revenind OnTopic: Si eu am acele vibratii/batai in coloana de directie la virarea pe suprafete denivelate, inca din primele zile. Ideea de mai sus cu furtunul de servo mi se pare cea mai apropiata de adevar deoarece am incercat si pe loc, pe zapada sa rotesc de volan si senzatia e de oscilatie elastica este foarte clara. Ori asta, ori ceva nu controleaza bine presiunea din servo.
Am sa re-ridic problema la service poimaine, in virtutea noilor informatii de pe zapada, pe loc.
    • Salutare tuturor! Revin după 2 ani în care doar am urmărit forumul.  Mașina a ajuns la 5 ani și 85.000 km și a terminat garanția si reviziile incluse în pachetul "fără griji". Cred că pachetul și-a meritat banii la cum pare că s-au scumpit piesele și manopera. Am văzut un deviz aici pe forum de vreo 4000 lei pentru revizia de 4 ani, cu schimb distribuție, iar eu nu am plătit nimic. Între reviziile oficiale, am mai făcut eu schimb de ulei cam la 10-12.000 km (fac cam 20.000 km pe an). Nu am avut nevoie de alte intervenții în service, iar cu antigelul nu au mai fost probleme. Și acum rezumatul acestor ultimi 2 ani Un prim accident în care cineva mi-a tăiat calea atât de hotărât încât pentru un moment am crezut că eu aveam cedează trecerea și nu am observat. Din fericire a apucat să treacă și doar l-am șters în frânare în partea dreapta spate. Dacă eram cu 1 secundă mai în față. cred ca intra destul de tare în mine.  Apoi, după 2 luni, un șofer din spate nu a observat că mă oprisem la trecerea de pietoni în spatele unei mașini care a frânat brusc (zicea că schimbase banda și se uita în spate) - s-a simțit destul de bine impactul. Și al treilea - anul acesta: de pe o străduță laterală a ieșit un șofer când am ajuns in dreptul lui. Am încercat să evit, dar aveam mașină pe banda din stânga si tot ne-am atins, dar a fost destul de ușor. Am mai avut un incident într-o seară, după această iarnă în care șoselele erau pline de găuri. Veneam spre casă pe centura București si am lovit o groapă plină cu apă. Mi s-a aprins senzorul de presiune destul de repede și deja simțeam că roata e dezumflată. Am mers până la prima benzinărie si am văzut că janta era strâmbă, dar din fericire anvelopa nu s-a tăiat - doar a făcut o mică gâlmă. Fix atunci intra în benzinărie un camion. Am împrumutat un ciocan, am îndreptat janta cât am putut, am umflat roata și am mers spre casă. Era sfârșitul iernii și am trecut curând la cauciucurile de vară și jantele pe 17. Probabil dacă aveam jantele de aliaj dauna era mai mare. În toamnă o să cumpăr alte anvelope - probabil voi trece la Grabber Cross A/S să rămân cu un singur set de anvelope și voi avea și lanțuri la mine pentru ieșiri mai grele.  La ultima vizită în service s-a constatat că amortizoarele pe spate au cam curs - simțeam și eu o schimbare în rău a comportamentului mașinii, mai ales la trecerea peste limitatoare de viteză. Încet-încet, vreau să aduc diverse îmbunătățiri mașinii, așa că am profitat de ocazie și am instalat amortizoare Bilstein by Mudster +2cm - pare că este cu totul o altă mașină. S-au schimbat și flanșele de amortizor pe față și asta a rezolvat o altă problemă pe care o aveam: uneori când frânam în timpul parcării, se auzea o bătaie. Inițial am crezut că ar putea fi o bucșă, dar la verificare totul părea în regulă. Repet poate la fiecare mesaj acest lucru: în continuare îmi place mașina foarte mult și nu am în plan să o înlocuiesc. Să fiu sincer, m-am gândit și nu imi vine în minte o altă mașină care să se potrivească momentan stilului nostru, cu un buget decent. Am reînnoit RCA și Casco la Allianz. Probabil o să ajung mai rar în reprezentanță - amortizoarele și schimburile intermediare de ulei au fost făcute în alte service-uri. Drumuri bune și să auzim doar de bine!
