Pornire la rece
  • Răspunsuri 1,2k
Voi sunteti siguri ca lipsa aceea de putere la 2000 rpm nu este de fapt lag-ul turbinei?
Da! Sub 12-13 grade afara nu se mai manifesta.
Eh, stie Dacia ce stie. Vine toamna acusi, deja dimineata pana inspre ora 10:00 sunteti in plaja de temperatura optima, pana la vara viitoare scapa de voi :) (no offence).
Si eu astept verdictul in dupa-masa asta, acum masina e la service, cu problema zgomotelor in coloana de directie si a greierilor din usile fata.
L.E. Citind un review din India (unde temeparaturile sunt constant in zona de problema) :
There is a bad amount of turbo-lag below 2,000 rpm, and the 109 BHP Duster only gets punchy above 2,200 rpm. The lag won't bother you much when starting off from a standstill, thanks to the short 1st gear ratio. However, it can seriously catch you out if you try to drive around town at low speeds in 2nd gear, or on inclines. The only solution is to downshift and get that engine into the turbo zone. For the same Munnar incline that our Innova cab did in 2nd gear, the Duster required a firm downshift to 1st. I had to make frequent downshifts in slow moving Kerala traffic that was reminiscent of Mumbai rush-hour conditions. It does take a couple of kms to get used to the lag and learn to drive around it. I wouldn't consider the lag a deal breaker, though the 84 BHP Duster offers far superior driveability in town. The 110 PS' turbo is unforgiving and you have to pay attention to choosing the right gear at lower speeds. In comparison, the 84 BHP Duster lets you get away with a less attentive style of driving.
Editat de DonQuijote
Si, intr-un final acest update a rezolvat sau nu problema sesizata in acest topic?
Nu, n-a rezolvat nimic...
Azi 11 grade afara. Am plecat dimineata, o placere sa mergi cu masina! Am mers cam jumatate de ora prin oras si surpriza (neplacuta)! Dupa ce s-a incalzit bine motorul, a reaparut lipsa de putere, cu toate ca afara tot 11 grade erau...
    • Salutare tuturor! Revin după 2 ani în care doar am urmărit forumul.  Mașina a ajuns la 5 ani și 85.000 km și a terminat garanția si reviziile incluse în pachetul "fără griji". Cred că pachetul și-a meritat banii la cum pare că s-au scumpit piesele și manopera. Am văzut un deviz aici pe forum de vreo 4000 lei pentru revizia de 4 ani, cu schimb distribuție, iar eu nu am plătit nimic. Între reviziile oficiale, am mai făcut eu schimb de ulei cam la 10-12.000 km (fac cam 20.000 km pe an). Nu am avut nevoie de alte intervenții în service, iar cu antigelul nu au mai fost probleme. Și acum rezumatul acestor ultimi 2 ani Un prim accident în care cineva mi-a tăiat calea atât de hotărât încât pentru un moment am crezut că eu aveam cedează trecerea și nu am observat. Din fericire a apucat să treacă și doar l-am șters în frânare în partea dreapta spate. Dacă eram cu 1 secundă mai în față. cred ca intra destul de tare în mine.  Apoi, după 2 luni, un șofer din spate nu a observat că mă oprisem la trecerea de pietoni în spatele unei mașini care a frânat brusc (zicea că schimbase banda și se uita în spate) - s-a simțit destul de bine impactul. Și al treilea - anul acesta: de pe o străduță laterală a ieșit un șofer când am ajuns in dreptul lui. Am încercat să evit, dar aveam mașină pe banda din stânga si tot ne-am atins, dar a fost destul de ușor. Am mai avut un incident într-o seară, după această iarnă în care șoselele erau pline de găuri. Veneam spre casă pe centura București si am lovit o groapă plină cu apă. Mi s-a aprins senzorul de presiune destul de repede și deja simțeam că roata e dezumflată. Am mers până la prima benzinărie si am văzut că janta era strâmbă, dar din fericire anvelopa nu s-a tăiat - doar a făcut o mică gâlmă. Fix atunci intra în benzinărie un camion. Am împrumutat un ciocan, am îndreptat janta cât am putut, am umflat roata și am mers spre casă. Era sfârșitul iernii și am trecut curând la cauciucurile de vară și jantele pe 17. Probabil dacă aveam jantele de aliaj dauna era mai mare. În toamnă o să cumpăr alte anvelope - probabil voi trece la Grabber Cross A/S să rămân cu un singur set de anvelope și voi avea și lanțuri la mine pentru ieșiri mai grele.  La ultima vizită în service s-a constatat că amortizoarele pe spate au cam curs - simțeam și eu o schimbare în rău a comportamentului mașinii, mai ales la trecerea peste limitatoare de viteză. Încet-încet, vreau să aduc diverse îmbunătățiri mașinii, așa că am profitat de ocazie și am instalat amortizoare Bilstein by Mudster +2cm - pare că este cu totul o altă mașină. S-au schimbat și flanșele de amortizor pe față și asta a rezolvat o altă problemă pe care o aveam: uneori când frânam în timpul parcării, se auzea o bătaie. Inițial am crezut că ar putea fi o bucșă, dar la verificare totul părea în regulă. Repet poate la fiecare mesaj acest lucru: în continuare îmi place mașina foarte mult și nu am în plan să o înlocuiesc. Să fiu sincer, m-am gândit și nu imi vine în minte o altă mașină care să se potrivească momentan stilului nostru, cu un buget decent. Am reînnoit RCA și Casco la Allianz. Probabil o să ajung mai rar în reprezentanță - amortizoarele și schimburile intermediare de ulei au fost făcute în alte service-uri. Drumuri bune și să auzim doar de bine!
