Pornire la rece
  • Răspunsuri 1,2k
Voi sunteti siguri ca lipsa aceea de putere la 2000 rpm nu este de fapt lag-ul turbinei?
Da! Sub 12-13 grade afara nu se mai manifesta.
Eh, stie Dacia ce stie. Vine toamna acusi, deja dimineata pana inspre ora 10:00 sunteti in plaja de temperatura optima, pana la vara viitoare scapa de voi :) (no offence).
Si eu astept verdictul in dupa-masa asta, acum masina e la service, cu problema zgomotelor in coloana de directie si a greierilor din usile fata.
L.E. Citind un review din India (unde temeparaturile sunt constant in zona de problema) :
There is a bad amount of turbo-lag below 2,000 rpm, and the 109 BHP Duster only gets punchy above 2,200 rpm. The lag won't bother you much when starting off from a standstill, thanks to the short 1st gear ratio. However, it can seriously catch you out if you try to drive around town at low speeds in 2nd gear, or on inclines. The only solution is to downshift and get that engine into the turbo zone. For the same Munnar incline that our Innova cab did in 2nd gear, the Duster required a firm downshift to 1st. I had to make frequent downshifts in slow moving Kerala traffic that was reminiscent of Mumbai rush-hour conditions. It does take a couple of kms to get used to the lag and learn to drive around it. I wouldn't consider the lag a deal breaker, though the 84 BHP Duster offers far superior driveability in town. The 110 PS' turbo is unforgiving and you have to pay attention to choosing the right gear at lower speeds. In comparison, the 84 BHP Duster lets you get away with a less attentive style of driving.
Editat de DonQuijote
Si, intr-un final acest update a rezolvat sau nu problema sesizata in acest topic?
Nu, n-a rezolvat nimic...
Azi 11 grade afara. Am plecat dimineata, o placere sa mergi cu masina! Am mers cam jumatate de ora prin oras si surpriza (neplacuta)! Dupa ce s-a incalzit bine motorul, a reaparut lipsa de putere, cu toate ca afara tot 11 grade erau...
