Salutare intregului forum, sunt nou aici si m-am inscris evident pentru ca am cateva probleme cu masina si poate ma sfatuiti.
Am un duster 1.3 TCE GPL prestige  VF1HJD2056330497de ieri mi s-a aprins si martorul ABS/ESP insa din cand in cand, uneori o pornesc si nu se aprinde, alteori sta aprins pana opresc motorul.
Se poate face ceva sau trebuie sa merg cu ea la reprezentanta?
  • Răspunsuri 404
Pe ABS
DTCStatus.pendingDTC : [00] No
DTCDeviceIdentifier : [f003] Supply Voltage
DTCStatus.testFailedSinceLastClear : [00] No
DTCDeviceAndFailureTypeOBD : 61443 [0xf003]
DTCFailureType.ManufacturerOrSupplier : 5 [0x5]
DTCFailureType.Category : [01] General Electrical Failures
DTCFailureType : [15] circuit short to battery or open
DTCStatus.testNotCompletedSinceLastClear : [00] No
DTCStatus.testNotCompletedThisMonitoringCycle : [00] No
DTCStatusAvailabilityMask : 9 [0x9]
DTCStatus.warningIndicatorRequested : [00] No
StatusOfDTC : 8 [0x8]
DTCStatus.testFailedThisMonitoringCycle : [00] No
DTCStatus.testFailed : [00] No
DTCStatus.confirmedDTC : [01] Yes
Pe climbox
DTCStatus.testFailedSinceLastClear : [01] Yes
DTCFailureType.ManufacturerOrSupplier : 8 [0x8]
DTCFailureType.Category : [00] General Failure Information
DTCFailureType : [08] Bus Signal / Message Failures
DTCStatusAvailabilityMask : 57 [0x39]
StatusOfDTC : 40 [0x28]
DTCDeviceIdentifier : [a4d3] LIN_Bus
DTC #1
DTCFailureType.ManufacturerOrSupplier : 2 [0x2]
DTCFailureType : [02] General signal failure
DTCStatus.testNotCompletedSinceLastClear : [01] Yes
DTCStatusAvailabilityMask : 40 [0x28]
DTCStatus.confirmedDTC : [00] No
StatusOfDTC : 16 [0x10]
DTCDeviceIdentifier : [a4b6] CentralPan
Salut. In primul rand din VIN lipseste o cifra, probabil ultima si atunci este VF1HJD20563304970 si un Duster 1.3TCe fabricat in 27.05.2019 cu nr. de fabricatie A365468. Apoi prima eroare (DTCF003) se refera la calculatorul distributie punte fata\spate, vezi doar ca ex atasat procedura ei de diagnosticare, dar daca VIN-ul acesta este corect tu ai o transmisie TL4(355). Nici celelalte doua erori din ClimBox nu par sa fie corecte (probabil citite cu ddt4all sau alt program derivat din DDT2000).
Daca doresti verifica din nou VIN-ul si poti eventual atasa o captura (macar pentru prima eroare) din programul de diagnoza in care sa se vada tot ecranul pentru a verifica daca a fost citita corect. Sau desigur asa cum bine s-a scris anterior poti apela la garantie (daca o mai ai) sau la cineva care are cunostintele si “uneltele” necesare pentru rezolvarea acestor erori \potentiale probleme. (“…  mi s-a aprins si martorul ABS/ESP insa din cand in cand, uneori o pornesc si nu se aprinde, alteori sta aprins pana opresc motorul.”)
PS: verifica totusi si bateria masinii.
Editat de Gil26
  • Mak pinned this topic
