Traseu Bucuresti-Suceava (445 km) am avut consum 9.6 si costul a fost de 140 ron.
Am mers mereu cu putin peste limita de viteza peste tot pe unde am prins. Imi pare rau ca nu am retinut viteza medie...
Recomand acest site pentru a va calcula consumul: https://gps-online.webshow.ro/calculator-consum.html
Pt. ca se pare ca e mai simplu din butoane...
"Duster2 (also Sandero3/Logan3/Jogger?): On the Duster2, all parameters are in the speedometer (Cluster_L1_L2) under Ecrans Configuration, Conf Entretien. As with Gen. 2, you can set eight values: interval and remaining days/km for both oil changes (Vidange) and maintenance (Révision). Resetting the counters to their initial values is more complicated (select the Oil drain reset or Service reset function from the RoutineIdentifierList and execute the routine using the Oil DRAIN RESET Exec button. It seems to be easier to reset the values in the on-board computer menu."
Sursa
Din acest topic eu inteleg ca ceea ce scrie in manualul de utilizare pt. Duster 2, nu functioneaza.
Am inteles eu gresit manualul si merge doar cu diagnoza ?
