  • Răspunsuri 999
Am primit urmatorul mail acum 5 minute de la un dealer din Pitest :"Buna ziua!
Din pacate tocmai am primit nota de retea ca motorul de 1.6 nu se mai gaseste pe Noul Duster, asa ca singurul motor pe benzina a ramas cel de 1.2 Tce 125 CP.
In mail gasiti atasat noua fisa de produs pentru Noul Duster.
Pentru mai multe informatii va stam la dispozitie.
Va multumesc !"   hmmm ciudata miscarea celor de la dacia
Citat
DUSTER TRAILS DRIVE TEST - STAGE ONE
(*Limba romana mai jos)
Our approach to words is far more spartan than the traditional automotive press. We simply say, that if you are driving a Skoda, Renault, VW, Duster Ph1, or if you love the Nature, going out with the family, love photography and if you enjoy a smart buy - then you have our FULL support/validation and recommendation to go and buy a Duster 2 Diesel, full options with 5 years warranty - right NOW. But if you are more of an offroader kind of guy, then we need to talk... as an upgraded Duster Ph2 might be your thing.
Duster 2 2018 (*vs Duster Ph2 2017 - *more details to come after Renault/Dacia figures out that the FB Community Groups, should also be able to get the cars for full proper testing outside the city).
Steering wheel handling - 80% Improvement
Car road handling - 25% improvement
Interior Soundproofing - 50% improvement
Engine Soundproofing - 60% Improvement
Suspension - 15% Improvement in Rigidity
Car Doors operation - 60% Improvement
Car Structure strength - 35%ish Improvement
Car design - 40% improvement with no upgrades
Diesel Engine Behavior - 10% Improvement
Seats Comfort - 10% Improvement
Interior space feeling - 30% Reduced
Functional Storage space - 40% Reduced (I said functional as you will not search between the legs of your fellow passenger under his seat).
Frontal visibility - 25% Reduced
Lateral visibility - 35% Reduced
Dashboard buttons Ergonomics - 45% Reduced (not driver friendly, small, cramped, difficult to identify by muscle memory).
Offroad Rescue Hard-points - 50% limited operational angles
Under-body Aerodynamics - Zero Improvement
Ground clearance - 21cm real (*lowest point) thought frontal shield is 22.5cm, 23cm can be easly obtained with a few modifications to the central traversal small metal sheet bar. I suspect the R17 is 1cm higher.
Engine Mapping capability - Unknown
Lateral Video Cameras? - Yes you need them to counter the reduced lateral visibility.
RO - Duster 2 se comporta la nivelul Skoda, Renault, este extrem de bine antifonat si inchegat. Cu o caroserie mai rezistenta si un motor mai flexibil chiar daca in aceeasi cai putere pe hartie. Daca conduceti Skoda sau Renault si doriti sa va indreptati spre smart-buy, atunci recomandam cu incredere Duster 2. Daca insa faceti offroad, atunci va recomandam un Duster 2 faza 2 cu upgradeuri in valoare de 2000 euro si sunteti extrem de aproape de Duster 2 chiar si depasindu-l, ramanand in urma doar la design si putin antifonare si rigiditatea caroseriei.
Hope it helps,
DT
Editat de Cain
Legat de disparitia motorului de 1.6 l aspirat, chiar si pe configuratorul dacia.ro, cum spunea un coleg, acest motor a disparut. Asta a facut ca pana si varianta de baza - Essential - sa primeasca motor turbo si, implicit, sa-i creasca pretul. Ceea ce mi se pare strange este ca acum, pe site, primele doua versiuni - Essential si Comfort - sa aiba acelasi pret de plecare : 14.550 EUR. Parca logic ar fi ca prima versiune sa fie cea mai ieftina, ca de asta nu are o serie de echipamente.
Cam multe balbe din partea Dacia pentru un model asteptat foarte mult si care constituie mare parte din vanzari, atat in tara cat si in afara, implicit o mare parte din productie.
Editat de vladionut
