  • Răspunsuri 999
Cine a testat 4×4  N.o sa m.ai vrea altceva! Pe mine personal m.a scos din multe probleme 4×4  si Nu voi renunta Niciodata la el! Va dau un exemplu recent in Austria a fost zapada f. Mare si sa v
Am preluat masina astazi in jurul orei 15 si am facut primii 100 de km si e super,  a scos un consum de 5'9 pe ruta craiova bals slatina dus intors.....mergand bara la bara in orasul bals. Multa
UPDATE: Ieri 04.10.2018 am fost sunat ca masina este pe drum inspre dealer si aseara am primit masina. Stresul acordat atat VC-ului cat si a Dealerului a a functionat ca picatura chinezeasca. Pot spun
Am primit urmatorul mail acum 5 minute de la un dealer din Pitest :"Buna ziua!
Din pacate tocmai am primit nota de retea ca motorul de 1.6 nu se mai gaseste pe Noul Duster, asa ca singurul motor pe benzina a ramas cel de 1.2 Tce 125 CP.
In mail gasiti atasat noua fisa de produs pentru Noul Duster.
Pentru mai multe informatii va stam la dispozitie.
Va multumesc !"   hmmm ciudata miscarea celor de la dacia
Citat
DUSTER TRAILS DRIVE TEST - STAGE ONE
(*Limba romana mai jos)
Our approach to words is far more spartan than the traditional automotive press. We simply say, that if you are driving a Skoda, Renault, VW, Duster Ph1, or if you love the Nature, going out with the family, love photography and if you enjoy a smart buy - then you have our FULL support/validation and recommendation to go and buy a Duster 2 Diesel, full options with 5 years warranty - right NOW. But if you are more of an offroader kind of guy, then we need to talk... as an upgraded Duster Ph2 might be your thing.
Duster 2 2018 (*vs Duster Ph2 2017 - *more details to come after Renault/Dacia figures out that the FB Community Groups, should also be able to get the cars for full proper testing outside the city).
Steering wheel handling - 80% Improvement
Car road handling - 25% improvement
Interior Soundproofing - 50% improvement
Engine Soundproofing - 60% Improvement
Suspension - 15% Improvement in Rigidity
Car Doors operation - 60% Improvement
Car Structure strength - 35%ish Improvement
Car design - 40% improvement with no upgrades
Diesel Engine Behavior - 10% Improvement
Seats Comfort - 10% Improvement
Interior space feeling - 30% Reduced
Functional Storage space - 40% Reduced (I said functional as you will not search between the legs of your fellow passenger under his seat).
Frontal visibility - 25% Reduced
Lateral visibility - 35% Reduced
Dashboard buttons Ergonomics - 45% Reduced (not driver friendly, small, cramped, difficult to identify by muscle memory).
Offroad Rescue Hard-points - 50% limited operational angles
Under-body Aerodynamics - Zero Improvement
Ground clearance - 21cm real (*lowest point) thought frontal shield is 22.5cm, 23cm can be easly obtained with a few modifications to the central traversal small metal sheet bar. I suspect the R17 is 1cm higher.
Engine Mapping capability - Unknown
Lateral Video Cameras? - Yes you need them to counter the reduced lateral visibility.
RO - Duster 2 se comporta la nivelul Skoda, Renault, este extrem de bine antifonat si inchegat. Cu o caroserie mai rezistenta si un motor mai flexibil chiar daca in aceeasi cai putere pe hartie. Daca conduceti Skoda sau Renault si doriti sa va indreptati spre smart-buy, atunci recomandam cu incredere Duster 2. Daca insa faceti offroad, atunci va recomandam un Duster 2 faza 2 cu upgradeuri in valoare de 2000 euro si sunteti extrem de aproape de Duster 2 chiar si depasindu-l, ramanand in urma doar la design si putin antifonare si rigiditatea caroseriei.
Hope it helps,
DT
Editat de Cain
Legat de disparitia motorului de 1.6 l aspirat, chiar si pe configuratorul dacia.ro, cum spunea un coleg, acest motor a disparut. Asta a facut ca pana si varianta de baza - Essential - sa primeasca motor turbo si, implicit, sa-i creasca pretul. Ceea ce mi se pare strange este ca acum, pe site, primele doua versiuni - Essential si Comfort - sa aiba acelasi pret de plecare : 14.550 EUR. Parca logic ar fi ca prima versiune sa fie cea mai ieftina, ca de asta nu are o serie de echipamente.
Cam multe balbe din partea Dacia pentru un model asteptat foarte mult si care constituie mare parte din vanzari, atat in tara cat si in afara, implicit o mare parte din productie.
Editat de vladionut
    • Salutare tuturor! Revin după 2 ani în care doar am urmărit forumul.  Mașina a ajuns la 5 ani și 85.000 km și a terminat garanția si reviziile incluse în pachetul "fără griji". Cred că pachetul și-a meritat banii la cum pare că s-au scumpit piesele și manopera. Am văzut un deviz aici pe forum de vreo 4000 lei pentru revizia de 4 ani, cu schimb distribuție, iar eu nu am plătit nimic. Între reviziile oficiale, am mai făcut eu schimb de ulei cam la 10-12.000 km (fac cam 20.000 km pe an). Nu am avut nevoie de alte intervenții în service, iar cu antigelul nu au mai fost probleme. Și acum rezumatul acestor ultimi 2 ani Un prim accident în care cineva mi-a tăiat calea atât de hotărât încât pentru un moment am crezut că eu aveam cedează trecerea și nu am observat. Din fericire a apucat să treacă și doar l-am șters în frânare în partea dreapta spate. Dacă eram cu 1 secundă mai în față. cred ca intra destul de tare în mine.  Apoi, după 2 luni, un șofer din spate nu a observat că mă oprisem la trecerea de pietoni în spatele unei mașini care a frânat brusc (zicea că schimbase banda și se uita în spate) - s-a simțit destul de bine impactul. Și al treilea - anul acesta: de pe o străduță laterală a ieșit un șofer când am ajuns in dreptul lui. Am încercat să evit, dar aveam mașină pe banda din stânga si tot ne-am atins, dar a fost destul de ușor. Am mai avut un incident într-o seară, după această iarnă în care șoselele erau pline de găuri. Veneam spre casă pe centura București si am lovit o groapă plină cu apă. Mi s-a aprins senzorul de presiune destul de repede și deja simțeam că roata e dezumflată. Am mers până la prima benzinărie si am văzut că janta era strâmbă, dar din fericire anvelopa nu s-a tăiat - doar a făcut o mică gâlmă. Fix atunci intra în benzinărie un camion. Am împrumutat un ciocan, am îndreptat janta cât am putut, am umflat roata și am mers spre casă. Era sfârșitul iernii și am trecut curând la cauciucurile de vară și jantele pe 17. Probabil dacă aveam jantele de aliaj dauna era mai mare. În toamnă o să cumpăr alte anvelope - probabil voi trece la Grabber Cross A/S să rămân cu un singur set de anvelope și voi avea și lanțuri la mine pentru ieșiri mai grele.  La ultima vizită în service s-a constatat că amortizoarele pe spate au cam curs - simțeam și eu o schimbare în rău a comportamentului mașinii, mai ales la trecerea peste limitatoare de viteză. Încet-încet, vreau să aduc diverse îmbunătățiri mașinii, așa că am profitat de ocazie și am instalat amortizoare Bilstein by Mudster +2cm - pare că este cu totul o altă mașină. S-au schimbat și flanșele de amortizor pe față și asta a rezolvat o altă problemă pe care o aveam: uneori când frânam în timpul parcării, se auzea o bătaie. Inițial am crezut că ar putea fi o bucșă, dar la verificare totul părea în regulă. Repet poate la fiecare mesaj acest lucru: în continuare îmi place mașina foarte mult și nu am în plan să o înlocuiesc. Să fiu sincer, m-am gândit și nu imi vine în minte o altă mașină care să se potrivească momentan stilului nostru, cu un buget decent. Am reînnoit RCA și Casco la Allianz. Probabil o să ajung mai rar în reprezentanță - amortizoarele și schimburile intermediare de ulei au fost făcute în alte service-uri. Drumuri bune și să auzim doar de bine!
